I have a problem.
Old Sep 2, 2005 | 11:59 PM
ECG : Blindman's Avatar
Talking I have a problem.
Everytime I drive my truck anywhere my truck shakes when I start braking. Sometimes when I'm just driving I can feel my truck shaking a little bit. I need to know what is causing this. Is it the rotors or brakes?
Old Sep 3, 2005 | 12:10 AM
CDB03STX's Avatar
Sounds like your rotor(s) are warped... Changed brake pads lately? Did you replace or turn your rotors?
Old Sep 3, 2005 | 03:13 PM
uknigel2's Avatar
If the steering wheel feels fine when braking then check the rear drums and brakes for problems.
Old Sep 3, 2005 | 08:21 PM
jasonkola's Avatar
if your rotors are warped you should feel a pulsing in the break pedal. I wouldn't think the whole truck would shake unless they are really bad. I would be more likely to think wheel bearing or something in the break system is broke.
Old Sep 6, 2005 | 11:08 AM
1wicked element's Avatar
Could be the tires - that's what happened to me. I had a bad spot in one of my tires that was causing a "wobble" to the whole truck and in the steering wheel. You may want to check that.
I ended up having to buy new tires.
Old Sep 6, 2005 | 08:34 PM
KickinBlue4x4's Avatar
Chords might be separated in the tires, thats what happened to me....
Old Sep 6, 2005 | 08:55 PM
02sport4x4's Avatar
If it was his tires it would happen all the time though, not just during braking
