bfg 285/70/17
Old Jul 8, 2005 | 02:33 PM
sportmanst's Avatar
bfg 285/70/17
I'm sure this has been answered too....BUT.....the bfg all terrain 285/70/17 will fit stock 17x7.5 rims with no problems????....clearance...I have the '04 XLT with a 2.5" leveling kit will i have to do any trimming?
thanks guys
Old Jul 8, 2005 | 03:03 PM
wandell's Avatar
Yes, they will fit easily if you have a 4x4. If your truck is a 4x2, they will still fit, but it will be a little closer.
Old Jul 8, 2005 | 03:07 PM
sportmanst's Avatar
if i get a body lift + 35's will i need to regear or is what I have fine????
btw I do have the 4x4 w/tow package (what the really differs from not having I'm not sure other than an overly expensive hitch)
Old Jul 8, 2005 | 03:26 PM
wandell's Avatar
If you have a 4x4 with a leveling kit, you can fit 35x12.50's using the stock wheels. You may not have to regear if you have the 5.4 engine with 3.73 gears, even though it would be a good idea.
Old Jul 11, 2005 | 10:03 AM
sportmanst's Avatar
so u are telling me that SAFELY, meaning the tire is not being overly stressed, I can fit 35"x12.5" tires on the stock 7.5" wide wheel?
The tire guys i asked said I'd be crazy and need about a 9" wide wheel.
Is he nuts, or am i miss understanding something?
Old Jul 11, 2005 | 12:45 PM
mshane1's Avatar
Yes you can SAFELY run a 315/70-17 on your stock 7.5" wide wheel. I did it for several months before I bought my new wheels. Just play with your tire pressure to get max tire contact. As stated in many other threads running that tire on a 7.5" wide wheel, the wear will be as if you are running too much air pressure and MAY cause a slight bit more wear on the center of the tire.
