285/75/16 on '97 4X4?
Old Jun 27, 2005 | 07:23 PM
kars85's Avatar
probably a redundant question...but will they fit on my stock rims without any lift? according to my dad, the guy at the local tire shop said 255 was the biggest i could go on my stock rims or else the the tires would crown/warp back when the my previous set of tires were being mounted.
i'm looking for a little more beefier look and quality than my multi-mile 255/60/16's i have on now. thanks fella's...
Old Jun 27, 2005 | 08:07 PM
wandell's Avatar
285/75's will fit easily on your 16x7 wheels.
Old Jun 27, 2005 | 10:23 PM
kars85's Avatar
whatcha think?
Nitto Terra Grappler AT's
Old Jun 27, 2005 | 10:28 PM
Johngs's Avatar
You can fit 285s just fine.
And the Nittos are a great choice.
Old Jun 28, 2005 | 08:02 AM
wandell's Avatar
I agree, excellent tire.
Old Jun 28, 2005 | 09:02 AM
kars85's Avatar
will the 285's hang out past the fender much? also, will i need to make any air pressure compensations to adjust for the bigger tires?
Old Jun 28, 2005 | 11:51 AM
drteater's Avatar
I run 285/75 R16's on my 00 4x4 Scab with no mods whatsoever. You'll have no trouble and then don't stick out at all. 100% perfect fit.
Old Jun 28, 2005 | 08:13 PM
kars85's Avatar
thanks fella's...appreciate your help
Old Jun 28, 2005 | 09:12 PM
racerf150man's Avatar
i have the 285/75-16 bf goodrich on my 00 4x4. i run them about 40 psi instead of 35. no unusual wear or anything and turning is a lil better then it was with 35.
Old Jul 3, 2005 | 08:22 PM
Erikpn's Avatar
My friend installed 285/75/r16 on a 2000 F-150, BF Goodrich All Terrain, and they look great, no lifting required, but the front tires sometimes hit the side wall when you do a full turn.
