Bleeding 97 F-150 brakes
Old Mar 19, 2016 | 01:43 PM
Triguy450's Avatar
Thank you Masseyman for the quick response. It does have drum brakes on the back. I will readjust them again but I won't get to them until Wednesday.
Ed
Old Mar 19, 2016 | 02:20 PM
Are you sure you put the correct calipers on the correct sides? The bleeder screws need to be up top pointing up.
Old Mar 19, 2016 | 02:28 PM
Roadie's Avatar
I replaced the master cylinder and the calipers on my truck. I bench bled the MC a very long time to get all of the air out. Then I gravity bled the calipers with a plastic tube connected to the bleed valves and then sticking through the top of a jar. After the end of the plastic tube was under the fluid it couldn't suck air back in even if i pumped the pedal. I bled my truck's brake system by myself!!!
Old Mar 19, 2016 | 07:53 PM
Triguy450's Avatar
Thanks GLC, yes I made sure the correct calipers are on the correct side.
Roadie, that was another thing I planned to try. Allow gravity to bleed out the system. Thank you for the idea.
Old Mar 21, 2016 | 12:03 PM
mkosu04's Avatar
Originally Posted by Triguy450
I replaced, the front calipers, discs, rear brake pads and the left rear brake cylinder. I used a 2 power bleeders, one the sucks the fluid through the lines the other a pressure bleeder.
I have bled all 4 lines 3 times and continue to have a mushy pedal.
Any thoughts??
Is the bleed screw on the top or the bottom of the calipers you installed???
Old Mar 21, 2016 | 12:22 PM
Triguy450's Avatar
The bleed screws are on top as they are supposed to be as were the original ones I removed.
Old Mar 22, 2016 | 12:28 PM
mkosu04's Avatar
oops - I somehow missed that the first time... I think I never read page 2?
This is a common mistake though - I've even seen a technician do this at a big 3 headquarters. (I won't name them, but it wasn't Ford)
You probably just have some air lingering in the system. Keep bleeding.
Use care not to "bounce" the pedal against the floor. This can suck a small amount of air back in and make it harder to bleed.
Old Mar 22, 2016 | 02:21 PM
Roadie's Avatar
Originally Posted by masseyman
Do you have drum brakes in the rear? If so the shoes may not be adjusted up properly. Did you have a mushy pedal before you replaced the parts?
I've had this problem before on a Contour. If the rear brake shoes are not adjusted so that they are close to the drum, the pedal will be mushy.
