Problems With '04 F150 Lug Nuts??? HELP!!!
Old May 26, 2005 | 02:35 PM
GroupOne's Avatar
Question Problems With '04 F150 Lug Nuts??? HELP!!!
I have a 2004 F150 4x2 and I've been having some serious problems finding lug nuts that will fit with my aftermarket wheels. After going to O'Riellys, Autozone, Napa, and Carquest, I finally found some in our size 14mmx2 but now the center caps that cover the lugs nuts and hub won't fit cause the chrome lug nuts are too long so now I need open ended lug nuts that are narrower than the stock lug nuts. Of course the local Ford dealer is clueless and they couldn't even understand why I would be putting aftermarket wheels on my truck, morons. I've checked all the car parts stores around here and they don't even have anything in their parts books. The only feesable suggestion anybody has made is to chop the top off of the chrome lung nuts. Anyways, has anybody else had this problem or any advice?
Old May 26, 2005 | 02:43 PM
jcc's Avatar
jcc
You Should Be Able To Find Shorter Bolts Or Cut The Existing Ones.
But I Probably Wouldnt Do It
Old May 26, 2005 | 03:00 PM
LittleTow's Avatar
Get ahold of the wheel manufacturer - they should know what you require or at least point you in the right direction if they are worth a grain of salt.
