Need Wheel Help FAST!!!!!
Old May 13, 2005 | 05:43 AM
GA FX4's Avatar
I have a leveling kit and I want some of these wheels. Will any of these fit my 04 Screw with 33's no rubbing without sticking out much? Any pics of these wheels on an 04? THANKS!!!
Pro Comp 1069
17x9, 2mm, big 6 lug
17x9, 8mm, big 6lug
17x9, 2mm, small 6 lug
18x9, 2mm, small 6 lug
Old May 13, 2005 | 07:58 AM
wandell's Avatar
What does the "small 6 lug" and "big 6 lug" refer to?
Old May 13, 2005 | 01:17 PM
GA FX4's Avatar
I'm not really sure but the guy that is selling these wheels says they'll fit. I knew I could probably count on you Wandell! Please help! Thanks!
Old May 13, 2005 | 04:24 PM
wandell's Avatar
If the backspacing is 5 inches, they should fit, but they will stick out some. The bolt pattern should be 6x135mm.
Old May 13, 2005 | 05:59 PM
GA FX4's Avatar
I'm guessing the backspacing is 8mm and 2mm.
Old May 13, 2005 | 11:02 PM
wandell's Avatar
That must be the offset. If the wheel had 2mm of backspacing, almost the entire tire and wheel would be outside the fenderwells.
Old May 14, 2005 | 08:31 AM
GA FX4's Avatar
Oh ok. I really have no idea what he's talking about. That is all the info on the wheels he gives. Thanks!
Old May 14, 2005 | 09:38 AM
wandell's Avatar
Go to Pro COmp's website and see what the specs are.
