Stock Tire pressure
Old Mar 7, 2005 | 12:48 AM
jero's Avatar
Question Stock Tire pressure
I need to know a stock tire pressure.
Does anyone have a 98 f150 swb 4x2 with the factory 255 70 r16 size tires?
If anyone knows the Ford recommend tire pressures listed on their door jamb, please let me know!
Any help would be great!
thanx
Old Mar 9, 2005 | 12:13 AM
lonnie brown's Avatar
on the side walls of your tire's you will find the max tire psi...
Old Mar 9, 2005 | 12:28 AM
cjw3cma's Avatar
DO NOT inflate your tires to the MAX pressure shown on the sidewall. Check your vehicle's manual and using the figures listed as your guide, inflate a couple of pounds above those figures. Your ride will be not as cushy but your mileage will be better.
Old Mar 9, 2005 | 11:23 AM
jero's Avatar
pressure
tire shop said 3 pounds less per tire than the stock recommended. In my case w/ bigger tires, it's 29 front, 32 rear. Thanks for the info.
