2004 rims fit on 1999 F-150?????
2004 (Lightening) rims fit on 1999 F-150?????
You may want to check with your dealer/ford rep if you need the equivalent to their "NOTE: F-150 requires M-1010-L Lightning wheel steering stops". These wheels appear to be the 18" dia. by 9.5" wide with 14mm studs.
As wandell said, your lug nuts/studs are most likely 12 mm while those rims are designed for 14mm studs.
Check out ford's website for their pricing, etc. @:
http://www.fordracingparts.com/parts...tKeyField=5703
Wandell, Can the hubs/studs be changed out? If so, what is involved?
