31's
Old Dec 23, 2004 | 12:14 AM
rideblue450's Avatar
31's
im thinking about getting new rims, but running a stock 31- maybe a BFG all terrain or somethin, but i want to level the front of my truck out, i have a 2000 f150 extended cab 4x4. how much is it to level the front?
Old Dec 23, 2004 | 08:04 AM
wandell's Avatar
Cranking up the torsion bars is free. Afterwards you need a front end alignment. In my area that is $39.00, except Tuesdays when they have a $29 special. Also, most 4x4's came with a 32 (265/70-17) inch tire, so I'd at least go with that or a 33.
Old Dec 23, 2004 | 03:08 PM
i think a 33 will rub without a body lift? pllus i still want some suspension clearance. what are your thoughts
Old Dec 23, 2004 | 03:41 PM
wandell's Avatar
When I mounted my 33's (285/75-16) on my stock 16x7 wheels they were not even close to rubbing. When I mounted them on 16x10 inch wheels, they barely touched the front bumper's lower valance. I trimmed about a 1/2 inch of plastic off that and the problem was solved.
Old Dec 23, 2004 | 03:51 PM
is there any negative side to cranking the torsion bars? what about clearance with the 33's? is there any room for suspension to move?
Old Dec 23, 2004 | 03:55 PM
wandell's Avatar
The biggest negative to cranking up the torsion bars is that the initial portion of the suspensions travel is stiffer. Some people hate the stiffer ride, some love it. You can try for yourself and if you don't like it, return to the stock settings. Also, you don't have to crank up the torsion bars to fit 285's if you are using the stock wheels or 8 inch wide wheels.
Old Dec 23, 2004 | 07:32 PM
yeah i think im going to go with 16x8's and a 31 or 32, and maybe level the front, we;ll see- is it hard to do this?
Old Dec 23, 2004 | 10:43 PM
wandell's Avatar
It's not hard at all. Just take an 18mm socket and turn each adjustment bolt the same number of turns untill you get the height you desire. Some people jack up the front of the truck while doing this, some don't.
