anyone know this tire size?
Old Nov 28, 2004 | 06:28 PM
chillindude010's Avatar
Im doing the 3 inch body lift just like this truck has been done on this site. Can anyone tell me what size tires those are on his trucks. I think those are the 17s but i have the 16s. What would compare to that size or should i go bigger than that. I think im going to put the leveling kit on the front. I post it on another thread but should i really worry about changing the spare out or will that even fit under that part of the bed.
https://www.f150online.com/galleries...w.cfm?num=5287
Old Nov 28, 2004 | 08:20 PM
shroomjohn's Avatar
The bgf's on the bottom are probably 265/70/17 the meater ones at the top are 275/70/17 or 285/70/17 I think the 285's look better or even a 305/70/16 with that or the 285 you might have to crank the torsion bar or do a bit of trimming. The equal your looking for will usually be the same except the last digit will be 16 for your rim.I run the 305/70/16 and only had to crank the torsion bar an inch.I want to get wider rims then will definatley have to trim.Good luck post pics here's mine
