Wheel extremly difficult
A) 35
B) 122
C) 200Note: Requires minor modification to the OEM steering knuckle
Hi
I need 17" inch wheels for my almost new mickey thompson 33X12.5R17 MTX. Also I want to fit a Brembo gran turismo brake kit which has a thicker caliper than stock (doesn`t fit under stock wheels). The necesary clearance between the wheel spokes and the caliper is the A) measurement at point B and C in the image or link above. Nobody has given me a solution, I have asked everywhere. I would be very thankful if anyone knows a17", 8" to 10" wide wheel that would fit in my 98 F150 4WD.
Four Wheel Parts sells a 17x9 wheel with the 5-135 bolt pattern for the 97-03 F150. It is an extreme alloy series 1059, which is similar to a weld stonecrusher only a helluva lot less money. Check it out at http://www.fourwheelparts.com/4wp/pr...HEELS&man=PCW.
