Rotor Size Selection 2000
I have a 2000 EXPY 4wd 5.4 liter. I am going to replace the rear rotors.
How do i tell if i have 12mm or 14mm studs without removing the wheel ? All the parts stores cant help me.
if you have stock lug nuts and they are 21mm wrench size then you have 14mm studs if you have stock lug nits that are 19mm then you have 12mm studs. thats the easiest way i know but if you have after market wheels they might have 21mm lug nuts but only 12mm studs. you can also measure stud diameter and some stock wheels will have a stamping on them that will say 12mm or 14mm on the back.
