biggest tire without trimming... 6in"
probably going to go with fab tech first when i get the truck and I would like to get the tires at the same place. What would be the biggest tire i could get without rubbing? I would like at least 37"s is it possible?
Want to do the 3" body and add a leafs in the back too, but that might go down a month later. should i do the 3" body lift before the suspension lift?
bigtruck311... did you have to do any trimming to fit ur 38"s?
i would do the body lift first and then the suspension and you sould at least get a 37" tire. and this may sound crazy but i had a 2001 dodge with a 6inch fab tech lift and a 3" body lift with 44" boggers on it and only rub once in the front
to fit my 38" i had to cranc the torsion bars all the way and i had to cut some off the lower plastic valance, it dont look bad where you cut it you cant even tell unless you see a stock truck, if you have any ? just post them
