speedo?
speedo?
how much do tires affect the speedo? i went from stock 255/70/16
to 285/75/16 and was wondering how much this would affect the reading and how this is figured.
thanks terry
thanks terry
Tire calculator
Try this link;
http://www.miata.net/garage/tirecalc.html
You can enter your original size of tire and wheel, then the new size. It will give the diferences in dimensions as well as the revs per mile and percetage difference in the speedo. I use it for all my vehicles. Check it out.
Something else to think about, if you don't have it recalibrated you are putting less miles on your truck than you are actually driving. I went to Ford and they told me they could not adjust...I ended up buying the Hypertech Programmer to adjust for larger wheels and tires. Good Luck.
