16" Wheels Fit?
Old Sep 9, 2004 | 12:25 PM
jaturner133's Avatar
16" Wheels Fit?
Hi, looking for some help here.
I have a '98 F150 XLT Flareside 4WD with the Off Road Package & factory 17" wheels on it.
I am looking to put oversize or flotation tires on it, but the number & style of tires in a 17" size are very limited.
Will a set of custom 16" wheels fit this truck without interfering with the calibers or other hardware?
I understand the speedo could be affected, and will be trying to keep the same "overall" tire height as the factory tires so as not affect the ABS.
Just need to know if the 16"s will fit without rubbing anything.
Any help would be most appreciated.
Thanks,
Old Sep 9, 2004 | 04:15 PM
wandell's Avatar
Yes, 16's will fit. I would suggest a 305/70-16 (33x12.50) on a 16x10 inch rim. THe 305's are about 1 inch taller and 2 inches wider than your OEM 265/70-17's (32x10.50). With this combo, you will have to crank up your torsion bars or trim a little plastic off the front bumper's lower valance. Your speedo will be off a little, maybe 1 or 2 mph, but your ABS will not be affected.
Old Sep 9, 2004 | 07:17 PM
Thumbs up
Awesome! Thanks Wandell!
Now I can order the Wheels & Tires I wanted. Looking at the Swamper Trxus STS All Terrain. Confirmed they are available in a 33 X 12.5 X 16!
Just found this forum, will post pics of the truck soon.
Just picked my truck up a little while ago - had a Borla Cat-Back systyem installed. Sounds Awesome!
Thanks again for the help!
Old Sep 9, 2004 | 10:53 PM
wandell's Avatar
No problem. Also, welcome to the site!
Old Sep 10, 2004 | 11:52 AM
16" Wheels Fit - Follow Up
Hey wandell,
Just had one more question for you, if you don't mind.
Do I need to worry about any certain Backspacing or Offset with the wheels I buy, to make sure the 33X12.5's fit?
Thanks for all the help!
Old Sep 10, 2004 | 03:50 PM
wandell's Avatar
Most of the aftermarket wheels have 4 1/2 or 4 5/8 inches of backspacing, which is what you need.
