Brake Rotors?
Old Sep 8, 2004 | 08:39 AM
daywen's Avatar
Brake Rotors?
I need some new front brake rotors. When I went to Autozone, they asked if I had rear only ABS, or All Wheel ABS. How can I find this out?
1997 F150 Extended Cab 5.4 4x4
Thanks for your help!
Old Sep 8, 2004 | 11:06 AM
peteandtonya's Avatar
rotors/abs
Hi daywen, If you have the owners manual it should tell you what you have. VIN number code maybe? Local Ford dealer should be able to tell you.
Old Sep 8, 2004 | 06:34 PM
mattadams's Avatar
Chances are with a 97, you've got rear-wheel only, unless you PAID for the upgrade to 4-wheel ABS, which most people didn't. There is an extra cable going to your brakes which is how you know, but its tough to describe it. I'll see if I can find a pic or something to check for sure.
