ABS light blinking and won't go into gear.
Old Aug 9, 2004 | 10:03 PM
SouthernBoy's Avatar
Angry ABS light blinking and won't go into gear.
Looking for anyone who has had this same problem....
After I replace the fuse which is no. 13 in the engine fuse box (a 15 amp fuse for Brake On/Off Switch, Rear Anti-Lock Brake Module, and Brake Pressure Switch), the truck will crank up and go into gear for about 12 to 24 hours. Then, after a night or so when I go to start the truck and drive off, the ABS light comes on and blinks. The gear will not come out of park either. After I check and replace the fuse again, this starts all over again.
Does anyone had this problem before or know whats going on here? Any help is much appreciated.
Old Aug 10, 2004 | 02:11 AM
Mr_Bentwrench's Avatar
do a search for the brake sensor on the master cyl. they leak and short out sometimes. lots of info on these boards about that problem.
Old Aug 10, 2004 | 02:26 AM
Smile
Thank you
