do larger tires require speedo recalc?
howdy gents,
i recently upgraded my 2001 screw 4x4(offroad pkg) to 285/70 r17 tires. certainly these are
larger than the oem tires.
while ford cant give me a definitive answer as to
what tire diameter my truck shipped with,
i needed to ask if after a size increase, do i need
to have the speedometer reset ?
that is, does my abs or anything else get screwed up if i have later diameter tires
than the oem? what hazards do i face?
obviously mpg, current speed are wrong now.
tia, jackc...
tia, jackc...
Our Ford dealer wants $80 to recalibrate computer for larger tires. My original tire size was on the driver side door tag.Here is a handy little site to help calculate the changes:
http://www.miata.net/garage/tirecalc.html
Funny you should mention, I also upgraded my wheels and tires went from 30" to 33" 285/75/16's and ford also told me that they could recalibrate for me but when I got down to the shop they said no can do apparently Ford have specifically told them not to change it out the guys says "sorry buddy, I'm sure we can do it but they said no" I picked up a JET performance AccuSpeed Speedometer tool for mine for $150 and this can be used to correct gear changes as well as tire and wheel changes I know Superlift also sells one I think it is TruSpeed or something like that the install looks pretty straight forward if you are mechanically inclined which I am not so install will cost me about $140 at Four Wheel Parts. Check www.Truckperformance.com thats where I got mine.
In order to make everything read and act normally you need to have the computer recalibrated for any change in tire diameter. The way Ford's computer is setup to use revolutions per mile. Now ideally to get it dead on would be to measure the actual number of revolutions per mile instead of going by the tire manufacturers specifications. This can be done by either obseriving it for a mile (maybe the most accurate, but not the most feasable), or it can be done mathmatically by finding the distance traveled in 1 revolution and dividing this into a mile. This will compensate for tire inflation, variability in each tire, and wheel width mounted on. But any Ford dealer can do this and I have yet to hear (aside from this one) a Ford dealer say that corporate HQ telling them not to change it. I've heard of alot that say its not possible, but it is. Simply print out these instructions and give them to the tech. The revs/mi listed below are somewhat of a generic listing, but if you can't find them from your tire manufacturer these will get you pretty close. Now just for a little FYI as to why they can't program above a 35" tire is that as listed below you can't go below 601 rev/mi which is right at about what a 35 is. As I recall a 35 is between 601 and 599, depending on different variables.
Here are the detailed procedures:
1) Ensure all harness connections are plugged in.
2) Using Rotunda New Generation Star (NGS) scanner and Version 3.2 or higher Service Card, plug into the DCL connector.
[ADDED: Do not use a service card version later than early 2001 model year. This will not work if you try to use a service card dated after the 2002 models came out. But it will work on 2004 or earlier trucks with PSD engines if you use a Service Card for 2001 or earlier SuperDuties.]
3) Turn Key on w/Engine Off.
4) Select Service Bay Functions
5) Select ABS Module or 4WABS Module depending on application.
6) Select Tire Size/Axle Ratio Configure.
7) Enter tire manufacturer's specification of revs/mile (tire revolutions per mile) into the NGS as the REV.PER MILE figure, preceeded by two zeros.
[ADDED: To have an even more accurate odometer, enter the following rev/mile:
For 285/75R16 tires enter 00636
For 295/75R16 tires enter 00626
For 315/75R16 tires enter 00601
Do not try to enter a number less than 00601.]
8) Select Tone Ring size and verify that 120 is programmed in.
9) Select <Option> and press TRIGGER.
10) Select <Vehicle> and press TRIGGER.
11) Press <Done> and the Module will be reprogrammed.
12) Check Speedo accuracy.
this is good to hear
you guys are awesome in your knowledge.
i'll go see if my dealer will help, if not,
i can manually recalculate.
i read of some large tire installs doing things like
confusing the abs so that pressing the
brakes didnt stop the wheels from turning.
that is downright scarey so i had to ask.
sure do love my new rubber, the
goodyear mt/r's seem like a decent setup.
too bad i didnt see the 285/75 option though...
thanks again,jackc...
There is no way to manually recalculate unless you're just trying to compensate for the misreading on the speedometer. Reprograming can only be done by the scanner listed above or by a microtuner. The Superlift true speed and other things like that don't actually reprogram anything, but send a modified signal so things read right. If this particular Ford dealer doesn't do it find a different one and take them the directions on how to do it. Now I ran 285/75/16s for over a year on mine and didn't have any issues with the ABS system. I also ran 315/75/16 for almost 2 years and still had no ABS problems. Thats about the only thing that I DIDN'T have problems with. While it is best for the ABS system to get the computer reading right the biggest improvement that this will make is putting your shift points back to stock. You won't believe how bad its acutally shifting until it gets put back to where it should be.
