285 - 60 X 18 - 51 psi?
Old May 30, 2004 | 01:44 PM
UH O F150's Avatar
Cool 285 - 60 X 18 - 51 psi?
I have a set of Kumho tires and they read on the sidewall that the max psi is 51. I usually run around 35 psi and I was wondering if I should go higher. I have a 2000 F150 extended cab.
Old May 30, 2004 | 03:46 PM
ConcreteGuy's Avatar
They state the highest allowed pressure for the tire but it does not mean you go that high in general use..I use 35 PSI and it has worked well in my van and my 150 truck...one runs a 16" wheel and the other a 17"...Also the higher the tire pressure you run the harder the beating the truck and running gear take...
Old May 31, 2004 | 02:46 AM
Lonster's Avatar
Re: 285 - 60 X 18 - 51 psi?
No.
Lonster
Old May 31, 2004 | 10:09 AM
UH O F150's Avatar
thanks guys just wanted to be sure
