How do you figure tire height?
Old May 11, 2004 | 08:38 PM
OzarkExpedition's Avatar
I was looking at 1010tires.com, a URL that I got from another post here...
When doing a search for tires to fit my Expy they listed 16" tires at P255/70R16. I have the 17" wheel so I upsized and it listed what is on my truck the P265/70R17.
How do you figure the overall tire size for each of these? I am looking to see what the difference would be if I went to 16" wheels and tires.
Old May 11, 2004 | 08:49 PM
max mitchell's Avatar
http://www.ring-pinion.com/calculato...latorsind.html
Click on this, then on "tire height" on the left and insert numbers.
Old May 11, 2004 | 08:57 PM
Beardoge's Avatar
Easy Here's how
265/75 -16
265 MM is the tread width
75 is the percent of height of sidewall to tread width
16 INCH rim diameter
So 265 divided by 25.4 (converts metric to english) = the tread width.. 10.433 Okay stay with me...
Times .75 (75%) = sidewall height (7.824) X 2 for both sidewalls the top and the bottom of the tire. =15.649..... Stay with me now....
Plus 16 inches (rim diameter at the bead) =31.649
Tah Daaa that's you tire height 31.65
Easy Huh!!
Old May 11, 2004 | 09:16 PM
SlvrBltOffRoad's Avatar
A 255/70R16 is 30.2", a 265/70R17 is 31.9".
a 265/70R17 is the same as a 265/75R16
just a little tidbit
Old May 11, 2004 | 10:34 PM
Okay. That is easy, both the calculator and the math.
Thank you all for your replies.
Here is my delimma. I have an Expy that has 17" wheels stock tire size is 265/70R17. In the manual it says that with 16" wheels my truck can 500 more lbs of trailer weight. Is this because of tire size or because of wheel weight or what?
I was thinking that when it came time to get new tires that I would just get smaller tires and put them on the 17" wheel.
Would this compensate for the difference or am I missing something?
Thank you.
Old May 12, 2004 | 07:25 AM
APT's Avatar
APT
I am 95% confident the higher tow rating for 16" rims has to do with the shorter effective gearing. The largest 16" tire availible for Expy's was at least 5% smaller in circumfrence than 265/70R17. That's like changing the gear ration from 3.55 to 3.73, thus giving you a better torque multiplier.
Replacing your tires with something a little smaller is a good idea if you wnat better towing response, but if you are near the Ford rated limits, you should think about upgrading the tow vehicle.
Old May 16, 2004 | 09:48 PM
ConcreteGuy's Avatar
Upgrading tow rig
This is true I agree APT...Also...With upgrading your rig to tow more weight you will get better brakes to stop it when you need to as well...You need good brakes when towing anything in my opinion....
