squeaking pads
Old Apr 9, 2004 | 11:16 PM
gmf150's Avatar
squeaking pads
I have a problem with my 99 F150 front brakes making a hugh pitch squeal when the brakes are not engaged. When I apply the brakes, it stops.
I'm told it may be the pads, but both metalic and ceramic pads have been tried by the shop.
It was suggested maybe try organic (?) pads? What pads do you recommend to stop this....it's driving me nuts!
Complete brake job was done, including turning rotors and rebuilding/replacing pistons. Not sure what else it could be besides the pads.
Old Apr 11, 2004 | 03:05 AM
5.4MAN's Avatar
Account Suspended For 14 Days For Terms of Service Violations
Unhappy mine too
i have 99 also....
it does the same also and from what i have heard theres a lot out there that does the same thing..i was thinking of going to a whole new set up / sloted rotors and high performance calipers.sorry i cant spell worth a ship.
Old Apr 12, 2004 | 07:55 PM
gmf150's Avatar
it's a fairly new problem
Interesting to hear this is common on the 99 models. I've had a brake job done before, and never had problems.
Old Apr 13, 2004 | 11:16 PM
03f150man's Avatar
are the brake caliper slides properly lubricated and working correctly. Use only a high temperature rated brake grease. Is your gas mileage/truck performance crappy? would suspect your brakes are dragging. i disagree with 5.4; from my experience this is not a common problem.
