Uneven Level?
Old Mar 31, 2004 | 01:14 AM
man44a's Avatar
Uneven Level?
In 2002 Fx2 supercrews, is the rear of the truck higher than the front?
Why is it set up like this? Is there a quick fix? Is there any reason to leave it alone?
Old Mar 31, 2004 | 01:42 AM
tdaily2's Avatar
they do this so when you put things into it it will take care of that or when you tow
Old Mar 31, 2004 | 07:36 PM
max mitchell's Avatar
Yes, rear is higher....For heavy loads and towing....Quickest fix is lowering shackles within limits....Yes, to haul/tow heavy loads and to eliminate driveline/pinion angle problems.
