tire rotation to prevent tire cupping
Old Apr 29, 2001 | 01:11 AM
Dave D's Avatar
Post tire rotation to prevent tire cupping
Late model radials can be rotated diagonally or front to back.
Whats' the best way to reverse / prevent tire cupping ?
Dave
97 F150 4x4 Ext Cab Long Box 4.6L Auto, stock, in showroom condition Oxford White/Gold BedRug
Old Apr 29, 2001 | 04:44 PM
Kenster's Avatar
Post
Dave D asked:
___________________________________________
I doubt you can reverse it. I think cupping is the result of tires not being balanced properly.
Old May 2, 2001 | 03:51 PM
cruzer's Avatar
Post
I rotated mine left to right and that wore
the cupping off. Then I rotated them front to rear on the same side. The wear pattern has been normal ever since.
'99 F150 XLT,Wedgewood Blue, 4.6 V8, SC, Penda liner, K&N FIPK, Superchip, Gibson 3" stainless single, Edelbrock IAS shocks
Old May 3, 2001 | 12:13 AM
BJays Red 150's Avatar
Post
Cupping is usually caused by two things:
1: a bad shock/strut. placing an uneven load on the tire with harmonic vibrations due to the pavement cause the tires to cup
2: Mostly cupping is due to lack of rotation. Obviously, more weight is in the front of the vehicle , putting more stress on the front tires. Regular rotations prevent this.
If you move your now cupped tires to the rear, they should even out. Just know, cupping generally cuts the life of your tires down a little. Just keep with the maintanance!
2000 4.2 Supercab XLT
What I've done: K&N filter, Magna flow custom exaust (From where cat's join, 3"in, two 2.5" out the rear), Michelin LTX M/S 265/75/16's, MTX Thunderform custom box with two 6000 series 8" subwoofers and Mtx 120 amp.
Plans: Lund hood deflector, superchip, Poweraid, Xenon sport Flares, (custom ram-air idea?)
New: Pioneer DEH-P6300 Head unit (I definately reccomend it!)
