Speedo and Programer?
Old Apr 9, 2001 | 12:09 AM
Paul919's Avatar
Lightbulb Speedo and Programer?
I know that there are some programers out there that can change the speedo to your tire size anyone know what that programer is or a brand that does that?
Old Apr 9, 2001 | 11:07 AM
Ian N's Avatar
Thumbs up
Check out http://www.autotransinc.com/recal.htm - there was also a post last week on one of the boards about a competing product.
Also, if you have a 97 or 98, you can just change the gear on the Vehicle Speed Sensor (VSS).
Ian
99 Expedition EB
5.4l, 4x4, 4.10 LS
WMS Tube, Bassani Cat Back Exhaust, Superchip Flipchip
Old Apr 12, 2001 | 07:51 AM
dl_shaw's Avatar
Post
I'm going from 255/70R-16 to 285/75R-16
I've got a 97 f-150 ext cab 4x4 5.4, auto w/overdrive 3.55 gears. Is that enough info for my less then helpful friends at the local Ford dealers parts counter? I fear the worst as I have played the speedo gear game with those boys before............
Old Apr 13, 2001 | 01:28 PM
Ian N's Avatar
Post
Take the gear off, count the number of teeth and then multiply that number by 30.1/32.8 (the old and new tire sizes in inches). So, if you have 19 teeth now:
19*(30.1/32.8) = 17.4 - so you could go to 17 teeth (speedo would read a bit high) or 18 teeth (a bit low).
The best approach is to go in and say "I have a 19 tooth and need a 17 tooth gear", that way they can't screw it up. You might want to call a speedo shop - they usually stock those gears and probably have a better selection.
Ian
99 Expedition EB
5.4l, 4x4, 4.10 LS
