Wheel Sizes 135mm or 114mm ???
Seems like the rims come in 2 sizes. 5 lug 135 mm and 5 lug 114 mm. How do i know if they fit my truck. I have a 2001 supercrew. The wheels i found are expedition rims so i figured they would fit. what does this size refer to ? space between lugs ?
HELP
HELP
Like LGJ said 5 x 135. Unless you have the 7700# then it is 6 x 135. The numbering refers to the number of lug nuts and the bolt pattern used. For an F-150 it means 5 lug nuts on an 135mm diameter circle. So if you were to draw a circle that had a center point on the center of your hub and evenly space out 5 lug nuts in this case 72° apart you have an F-150 bolt pattern. The 5 x 114 is used on Explorers and I think that Rangers also use that pattern. Also 03 Expys have the same bolt pattern as an 04 F-150 so they won't fit either.
Joe
Joe
Typically they are not referred to as 5x114mm. They are usually refered to as 5x4.5", and yes every Ranger, every Bronco II, and 94-02 Explorers have used that bolt pattern. The only wheels that will fit on your truck is 97-03 F150 with the 5 lug pattern and 97-02 Expeditions. Those trucks are the only ones to ever use the 5x135mm pattern.
Well he got some of it right. They're 17" wheels with a 5 lug pattern
No Ford ever made has used a pattern listed as 117mm. Those wheels are a 5x135mm pattern.
Rule #1, alot of people on ebay don't **** about what they're selling.
No Ford ever made has used a pattern listed as 117mm. Those wheels are a 5x135mm pattern.Rule #1, alot of people on ebay don't **** about what they're selling.
