Speedo Recalibration on '00-'01s
Hey guys, I got a quick question here for those of you with digital odometers. I am planning on getting an '01 F-150 4x4 and noticed that the new odos are digital. When I had my Ranger, all I had to do was change the speedo gear in the transfer case to recalibrate for the bigger tire size. Can you still do this on the F-150 (is it mechanical?) or do you need a chip or something else. I don't plan on changing the gearing either.
--Sean
Happy Off-Roading!
Huntington Beach, CA
Soon to have '01 ORP
Administrator www.clubsi.com
RIP: '94 Ranger Splash S/C 4.0L 4x4 Auto
--Sean
Happy Off-Roading!
I have already talked to many people in my area about this. Alhough I am going to a smaller size tire rather than a larger size it should work the same on all 99-01 trucks with the digital odometer. I have been told that you need to have a ford dealership recalbrate your computer for the tire size. I was told that a chip can recalbrate for diffrent rear end gears, but can't recalbrate for tire size. It doesn't make any sense to me it's just the way that ford makes the trucks.
Has anyone actually had this done? Or is this just a legend or folk lore?
--Sean
Happy Off-Roading!
--Sean
Happy Off-Roading!
Neither Ford nor any of the aftermarket chip makers have been able to successfully reprogram the speedo on the '01 F-150s.
[This message has been edited by riotrob (edited 09-12-2000).]
For what it's worth, I had 275/70/16 Michelin LTX M/S put on my '01 SCrew today, and immediately headed put to the highway to check the speed/odo. At 60 mph indicated, a three mile course took 179.6 seconds one way and 179.55 seconds back, indicating the speedo (and therefore assumably the odometer) is just about dead nuts on. (off by what-%0.2). At 75 indicated, I am actually travelling about 1mph off. In conversation with a Ford Certified tech at the dealership, he said Ford will allow 4mph plus or minus before they get concerned.
For what its worth, here is my spedo correction (calculated over a hundred miles on the interstate):
'01 Supercrew
Orig: 255/70-16
New: 265/75-16
Speed (speedo/actual):
20 / 21
25 / 27
30 / 32
35 / 37
40 / 43
45 / 48
50 / 53
55 / 59
60 / 64
65 / 69
70 / 75
75 / 80
80 / 85
85 / 91
90 / 96
Mileage:
(odometer reading)x(1.0666)=(actual miles)
'01 Supercrew
Orig: 255/70-16
New: 265/75-16
20 / 21
25 / 27
30 / 32
35 / 37
40 / 43
45 / 48
50 / 53
55 / 59
60 / 64
65 / 69
70 / 75
75 / 80
80 / 85
85 / 91
90 / 96
Mileage:
I just called my local Ford dealer today and asked about the PSOM (Programmable Speedometer/Odometer Module) for the newer F-150s. The service advisor told me there is a formula they use to reprogram the computer and that they could do it no problem for me if I went to 33's when I get my truck. Just thought you'd like to know that it does exisit.
--Sean
Happy Off-Roading!
Soon to have '01 F-250LD
--Sean
Happy Off-Roading!
I contacted Hypertech and they will have a reprogrammer available around the 1rst off the year for 2000 f-150.They should have one for 99 before Christmas.You will be able to compensate for almost any upgrade including tire sizes.98 is available now.
On my '99, the local Ford place could NOT get the computer to accept the parameters for recalibration (235/70-16 to 255/70-16 & 3.08 to 3.55 gears) after repeated attempts. Superchips is the next option, as I have put larger tires on my '00 4x4. Mike Troyer is the man to talk to. Doc
2000 F-150 4x4
4.2L, 5-speed,
3.55 Limited Slip,
reg. cab, short bed,
Pioneer DEH-P4000 CD,
Tinted windows,
17" ORP wheels,
265/70-17 GY RT/S
Delta toolbox
Super-flip-chipped (soon to be re-programmed)
Tow Hooks
...much more to come....
Wife: 2000 Ranger Trailhead Package
Black & Tinted
5-spd, CD, A/C,
16" 4x4 wheels/tires, 4x4 susp.,
Westin nerf bars
2000 F-150 4x4
4.2L, 5-speed,
3.55 Limited Slip,
Tinted windows,
17" ORP wheels,
265/70-17 GY RT/S
Delta toolbox
Tow Hooks
Black & Tinted
5-spd, CD, A/C,
Westin nerf bars
