bigger tires for stock 17" wheels
Old Aug 10, 2000 | 06:34 PM
swamp rat's Avatar
Question bigger tires for stock 17" wheels
I've got a '98 4x4 extended cab that came with 17" wheels...currenty have P265/70/R17s...what is a bigger tire that might fit on these rims? I know about ProComp's 33"/12.5/17; are there any others? I don't want to lift the truck...at least not yet. Any suggestions would be appreciated.
Old Aug 10, 2000 | 08:44 PM
notloc1's Avatar
Post
Goodyear makes the Wrangler GSA in a 275/70R17 and will soon be making the Wrangler AT/S in the same. There is not a whole lot of info on tires for the Ford 17" rims, but I went out on a limb and just ordered the ProComp MT 305/70R17's. I got them for just a little more than what the GSA's would cost at Tirerack. I really wanted to get larger tires, but was tempted by the sale on the 265/70R17 Wrangler AT's at tirerack, but 4wheelparts.com will deal on the prices quite a bit. Also check out4xxxx4.com. I got the lowest prices here, but found them after i ordered.
Old Aug 11, 2000 | 11:26 AM
swamp rat's Avatar
Post
Thanks, notloc1. The Wrangler GSA LT275/70/R17 tires sound like a good deal. I got Walmart to order them for $119 each. Thats much cheaper than the P265/70/R17s I was planning on getting...
1998 F-150 XLT 4x4 Off-Road, 4.6, limited slip, automatic, Red, Supercab, 12-disk cd changer, limo tint, Custom Magnum wrap-around grill guard, Full-length nerf steps with custom brackets.
Old Aug 14, 2000 | 02:25 PM
FAST 4.6's Avatar
Question
notloc1.,
Have you installed those MT 305's yet? How do they fit? I talked to a guy that deals with Pro Comp and he said that they would rub on my truck (w/ no lift.)
98 F150 XLT 4X4 EXT CAB, 4.6L V8 AUTO, OFF-ROAD PKG., TOWING PKG.
3.55 LS K&N, DYNOMAX SUPER TURBO, DUALS, SST TONNEAU, TINTED GLASS
Old Aug 14, 2000 | 04:42 PM
christrucker's Avatar
Post
do they make a 315? I need some 315s (35s) and I really didn't want to buy new rims too, but looks like I will have to.
99 black f150 4x2 ext. cab sport w/4.6 V8. external mods. include:
3" body lift, airaid FIPK, JBA headers, Superchip headlight/taillight covers, wiper schroud, shadeblade, ventshade, bug deflector, bed liner, tonno cover, and Flowmaster Amarican Thunder cat-back system.
internal mods. include:
Pioneer indash cdplayer, 2 8" MTX subs, 400 watt amp, remote start, and aftermarket alarm
Old Aug 14, 2000 | 09:38 PM
notloc1's Avatar
Post
I just got the tires today, so i should get them put on this week. From earlier posts that i have read i think that i will be ok after tightening up the torsion bars a hair. From just setting the tires next to the truck it looks like i will have plenty of clearance front and rear of the tire.
I guess I'll find out though. I'll keep you posted.
[This message has been edited by notloc1 (edited 08-14-2000).]
Old Aug 15, 2000 | 01:29 AM
rextuff's Avatar
Post
Hey- probably too late, but I'm running a set of Mickey Thompson Baja Belted's on my '98. Don't have the specs in front of me, but they're 34's on my stock 17 inch rims. Only had to cut the plastic shroud at the front a little bit to make them fit. I have had them rub a bit at times, but only when doing some serious off-roading.
Old Aug 16, 2000 | 02:10 AM
powerlifter405's Avatar
Question
Food for thought.
I saw a blazer that had two nice face imprints in the windshield.
The tire blew when they were four wheelin' from the tire "rubbing a bit at times". It was a slow wearing process and was evident on the tire and fender.
Their set up was identical to mine but I went 1 tire size smaller. After seeing that, rubbing is not an option.
Both Mickey T and Super S make a 31x10 and 32x11 respectively. I saw a truck yesterday that had 33*13 Mickey T and there were signs of rubbing EVEN w/ a 3" body lift.
Anyhow, food for thought.
[This message has been edited by powerlifter405 (edited 08-16-2000).]
Old Aug 17, 2000 | 06:19 PM
notloc1's Avatar
Thumbs up
Well, I just got my truck with the new Pro/Comps. They ride great(On paved roads. dirt, and gravel), are not too loud(I can barely hear them over my exhaust) and make the truck look awesome(Personal opinion anyway). I have the ORP with the torsion bars turned a little(1/2"-1") and there is a ton of room left. I could be wrong, but I think that if my tires rub then I have more problems than just tire size. When you think about it though, the originl GY's are 32" and these are 33", so really you only loose 1/2" of clearance. Like I said before though, I guess I'll find out if I'm wrong because I'll see the wear on the tires and fenders. My first opinion is that Pro/Comp may have a solution for all the ORP owners looking for better/bigger tires.
1998 Lariat S/C Flareside 4.6L ORP
K&N FIPK Superchip Dynomax CatBack
Rancho RS9000's
Pro/Comp 33X12.50R17 MT
Old Aug 17, 2000 | 11:16 PM
Post
to compare, the tires mentioned are real close in height but what are the width differences.
I thought that the procomps were supposed to be close to 11-12 wide. Where as the stocks are just about 8" wide.
Notloc, have you been able to put them under compression and then turn the tires both ways to full lock? One way to accomplish this is to jack up the A-arm unit as much as possible. I had discount do this for me on my other truck and that helped a lot.
Keep us up to date on your tires. I'm looking to up grade from these GY junks.
Like you I want something like a MT but I want to keep the ride quality if possible, and lower noise levels.
Old Aug 22, 2000 | 11:12 PM
notloc1's Avatar
Post
I have not compressed the fron end , but I have checked for interference when the wheel is cranked. The original GY's had 8" of tread, but the section width was about 10" i think so these shoud be about 2" wider total. They have room even with the wheel cranked and it looks like it would be ok when the suspension flexes.
I have no complaints as of yet. I need to get my alignment done, but I was expecting that. I got to drive in the rain today and could hardly get them to bark. I reset my chip so my mileage sucked, but it should rise again.
Rancho RS9000's
Old Aug 28, 2000 | 08:57 AM
Bigwulfe's Avatar
Post
Notloc1 -
Do you have any pics of those Procomps on your rig? I'd really like to see how they look before ordering the 305/70R17s
Bigwulfe
Black 99 XLT 4X4 Sport, Flareside, SC
Old Aug 30, 2000 | 09:35 PM
mudbug's Avatar
Question
Notloc1
New to board....I am also looking at the Peo comps and would like to see pics if ya got them......
Old Sep 13, 2000 | 12:40 AM
hillrod's Avatar
Post
Did you put these on the stock 17" chrome rims or did you buy new rims? I was told the stock rims were 7.5" wide and would not accomodate that width. Pleadse let em know as I am installing the 3" spindles this weekend and I already did the 3" body lift. I am assuming that I will need to pick out some new rims( shucks I hate that....LOL not as much as she does) Just another reason to buy another toy for my toy.
j.rodney.hill@att.net
2000 Lariat
dash pro wood grain kit
cat back exhaust
F1 hood (real cool)
Westin chrome side bars
BullRings
Chrome toolbox
3" body lift
Mirage bug guard
K&N air filter
Old Sep 13, 2000 | 04:11 AM
1stnuford's Avatar
Post
Just a point of info. I have the Goodyear Wrangler 265/65/17 on my SCrew 4x4. They wander all over the road. Looking for another brand as we speak. I would definitly stay away from the Goodyears.
2001 SCREW;OX-WHITE/SILVER;5.4L;4X4;Skid plates;Limited- slip;Char-gray interior w/bench seat;Tow Pkg;17"Wrangler RTS With 10 Spoke Alum whls;CD;Slider Rear;NO DECALS/PIN STRIPES;Super-Chip;K&N filter.
