rims and offset
Old Feb 26, 2000 | 02:50 PM
4wheelncop's Avatar
Question rims and offset
What is the desired backspacing for the f150? I will more than likely use the 305 70 r16 tires and I like the Weld typhoon rims. I have seen them advetise a 9" width in this rim and that sounds great, but does anyone know if they will work for my truck? If not I guess it will be the 8" wheel.
1999 F150 XLT 4x4, 5.4L, white over silver 2 tone. Cat back Flowmaster duals with rolled stainless tips for the exit pipes, K&N filter charger kit, and a Lund wind deflector painted white to match. Clifford g3 alarm
[This message has been edited by 4wheelncop (edited 02-27-2000).]
Old Feb 26, 2000 | 04:02 PM
Don C's Avatar
Post
The back spacing, if that is what tou are talking about is 4 9/16 that is acording to the mickey thompson web page
1999 F150 4x4 4.6V8 regcab/shortbed
Oxford White with Wedgewood Blue two tone, with Blue Captains chairs
Bassani Cat Back, Superchip,Modified intake with modified K&N filter.
Centerline Saber rims 17x8" with Firestone GTA 275/60hr-17 tires.
Old Feb 28, 2000 | 10:07 PM
JMTruck's Avatar
Post
The backspace on our trucks stock wheels (7 1/2" wide) is 4 1/2". You can start from there.
98 4x4 Lariat SC 5.4L ORP, Tow Package, 3.55 LS in oxford white two tone. Only modifications, K&N Filtercharger and Stepshield door still protectors. Many more to come.
Old Feb 29, 2000 | 11:04 AM
ccla's Avatar
Talking
My rims are 9.75" wide. with a 4 1/2" backspacing. they stick out a little with the 35x12.5's on them
98 F150 2WD,Bright Red, Regular Cab, 4.2, 3.55, 5 Speed, Superchip, 2 Superchip Decals (I Think They Add 5 HP Each), 3 Inch Bullseye Lift Spindles, 3" Body Lift, 1" Coil Spacers, 3" Blocks In Rear,Manik Grill Guard,Nerf Bars, Vent Visors,Air Box Mod, Fog Lights Mounted In Front Air Dam ,4 Kc DayLighters, Back Up Lights, Alpine CD Player, 2 Kenwood Amps, 10 Inch MTX Blue Thunder SubWoofer, Tinted Windows. 35" BFGOODRICH ALL TERRAIN KO'S Mounted on 16.5x9.75 American Racing Baja Rims
..........."IF YOU CAN'T STOP, SMILE AS YOU GO UNDER"...........
'00 Toyota Celica GT( Wife's Car )
Pics @ http://www.angelfire.com/la2/ccla/
[This message has been edited by ccla (edited 02-29-2000).]
