Replacing my rotors
Old Feb 27, 2004 | 12:54 PM
Milwaukee's Avatar
Replacing my rotors
I need to replace my rotors on my 2000 F-150 Lariat 4WD 5.4L
I have replaced pads myself before, but never the rotors...
From browsing the old posts, I think I inferred that on my model, it is easy to replace the rotors (on the front)
Can anyone verify?
Once you take the tire off, the rotors pull right off correct?
Thanks in advance for your help.
Nik
Old Feb 27, 2004 | 01:06 PM
36fan's Avatar
Yes - they should come right off; however, they may be rusted on. If they are, take a hammer and smack them a few times.
Don't try to knock them off w/ the hammer - hit inward.
The vibrations will allow them to seperate from the hub. If you hit out on them, they can somehow get jammed onto the lugs and then have to be cut off.
Old Feb 27, 2004 | 01:35 PM
Milwaukee's Avatar
Thanks so much for the reply...
I waited way too long to get to these brakes, and I gouged the rotor BAD.
oops... lol
Thanks again..
Old Feb 27, 2004 | 02:33 PM
powerstroke73's Avatar
The one obvious thing that hasn't been said is make sure you remove your calipers first. After that you just need to separate the rotor from the bearing assembly. I would take some good rust eating penetrating oil (WD40) and spray around the center hole of the rotor and the wheel studs to try and free it up easier.
