This Will fit??
Old Feb 9, 2004 | 06:04 PM
Marlon_E's Avatar
This Will fit??
Hello
I own a f-250 1988 And im Planning in buying wheels and tires
The 2001 Lightning Wheels will fit?
my current wheels use 5 Lugs if that helps but i dont know much about The subject
So Help me
The auction ends soon if they fit I offer :P
Old Feb 9, 2004 | 07:31 PM
powerstroke73's Avatar
First things first, no F250 in 1988 ever had 5 lug axles, they were all 8lug. An no, even if you do have 5 lug axles (that would make it an F150) the pattern is 5x5.5". From 97-03 Ford went to 5x135mm patterns and no they are NOT interchangable. The only wheels that will fit on your truck would be from 1/2 ton 96 and older trucks.
Old Feb 11, 2004 | 12:57 PM
Marlon_E's Avatar
Ok Thanks for Your wisdom But I do have a F-250 With 5 Lugs thats the way they were builted in Mexico ...By the way the name in here was F-200 The other models remain The same
For Example in here The F-150 Is Called "Lobo" Translates wolf
and the others now are F-250 and F-350 and so...
From Country To country Things May change :P
