Rear drum conversion
Old Jan 24, 2004 | 08:24 PM
buckfarmer's Avatar
I have a 2000 F150 2WD with rear drum breaks. What would be required from a scrapped rear axle to convert this to disc? Also, what about the master cylinder? Would original one work or would I have to change it out? Would ABS system have to be modified?
Thanks!
Stephen
Old Jan 25, 2004 | 11:50 AM
GIJoeCam's Avatar
You'd be better off pulling the whole axle out of a salvage vehicle than trying to convert one. That'd be the easiest way. Swap the axle (make sure to check the gear oil level in the "new" one), bleed the brakes, and viola! You're done!
-Joe
Old Jan 27, 2004 | 08:24 PM
buckfarmer's Avatar
Thanks! I agree. I've spoken with a couple of salvage yards already. Time to bargain hunt and find a good deal!
Thanks again!
Old Feb 8, 2004 | 03:44 PM
LeanNCut's Avatar
Do a search under member JMC. (or mine) I asked the question a while back and he linked a website that sells a complete disc to disc, BRAND NEW, rear axle assembly for $600. That's new and less expensive than most junk yards I've checked.
