Custom rims.....
Well I finally got my 16x9 beadlocks finished and tires put on (only my puny 33's for now as the 36's will not be on it untill the spring) Just thought I would see what you guys think? They are for function ( i can run less then 5psi with no worries of losing a bead) but I was wondering if people think they look cool, or just wierd. Let me know.
I made them, and they are not too heavy. just imagine your normal steel wheel with about 5 pounds of plate, and another couple lbs for bolts? Probably wear the bearings out quick, but these will not be used to much on the street.
They do have a different look to them, but when you understand the functionality...they are awsome. Great work
Cheers
broken
http://www.CustomTiRings.com
Cheers
broken
