wheel sizes
Old Dec 17, 2003 | 04:38 PM
blackflareside's Avatar
wheel sizes
Hey everyone,
This is my first post so bear with me. I have a 97 f150 2wd flareside that I am wanting to lift and put bigger tires on. I do NOT want to take this off road but want to run the bigger tire for looks. So here are the questions.
Will a 15 inch wheel work on my truck or does it need to be a 16 inch or larger?
Can an 8inch wide wheel hold a 12.5 inch wide tire? (both pep boys and big o tires told me that a 15x8 wheel would hold a 33x12.5/15 tire. but I had seen on this site that some say it wont)
This is what I want to do so reply back with some honest answers if you could.
I want to put a 3 inch body lift on my truck. Then add 15x8 wheels with 33x12.5/w5tires.
Is this doable?
Old Dec 17, 2003 | 05:50 PM
D's RIG's Avatar
do to the larger calipers on our trucks you must run at least a 16" rim, anything smaller will not give the proper clearence.
if your already going to buy new rims, why not get a 10" wide rim.
Old Dec 17, 2003 | 07:36 PM
wandell's Avatar
If you are going to install a 3 inch body lift you could add 305/70-16's (33x12.50-16) on a 16x8 or a 16x10. The 33's will fit on both rims. If you add a 3 inch body lift it will put you at the same height as a stock 4x4. Here's a pic of my 4x4 Screw at stock height with 285/75-16 (33x11.50) BFG's on 16x10 inch rims to give you an idea of what your truck would look like with a 3 inch lift.
https://www.f150online.com/galleries...2888-38348.jpg
https://www.f150online.com/galleries...-889-38345.jpg
Old Dec 18, 2003 | 02:49 AM
Buckeye Rich's Avatar
Wandell,
I love the way your truck looks! That is awesome...
