How do you figure out tire sizes?
the 275 will be taller than the 265
97 F150 4X4
4.6 V8 K&N Filter
Manik Grill Gaurd with 2 KC daylighters
American Racing Baja rims
Goodyear Wrangler MT/R 305/70/16 Dual Exaust with 40 series Flowmaster
Panasonic DF-600U and MTX Thunderforms with MTX 6000 in it with a MTX Amp
Web Site http://hometown.aol.com/steveng0143/...sBlack4X4.html
If you have any Questions Email me at Steveng0143@aol.com
97 F150 4X4
4.6 V8 K&N Filter
<font face="Verdana, Arial" size="2">Originally posted by InfiniteMhz:
I have 275/60 R17 and want to go to 265/70 R17 would the tire be taller, shorter or the same?</font>
The second number is the aspect ratio. This is a ratio of sidewall height to width. In the example above, the tire is 7.28" wide, multiply that by the aspect ratio to find the height of one sidewall. In this case, 185x0.60=111mm or 7.28"x0.60=4.36".
The last number is the diameter of the wheel in inches.
To figure the outside diameter of a tire, take the sidewall height and multiply by 2,(remember that the diameter is made up of 2 sidewalls, the one above the wheel, and the one below the wheel) and add the diameter of the wheel to get your answer.
Example...185/60R14 85H or 185/60HR14
185mm x .60=111mm x 2=222mm + 355.6mm(14")= 577.6mm or 22.74"
So in your case the 275/60/R17 would have an overall heigth of 30.00" and the 265/70/R17 would have an overall heigth of 31.60"
http://www.tirerack.com/tires/tiretech/size.htm
I think you will see a little difference in the overall tire size but you will give up some performance in the meantime. Most of the lower profile 17inch tires are of the high performance type.
I currently have Goodyear 265/70-17 tires and they suck. My next tire (will change within the month) will be Nitto NT404's. Sized at 275/65-17 they are approx 3/4 inches smaller in hight and 1inch wider but ohhhhh they will bring your truck into a different world...
Black 1997 F-150 Supercab Flairside. 4.6L with Superchip, Jacobs DIS, K&N Generation II, Cat back Exhaust with Flowmaster 40 and MEG'S Stainless tip in front of rear wheel (nice rumble). 17" Off Road wheel pkg. Lots of body mods. 4 yrs old and still turns heads...and now paid for!!
Here is a nice site for you guy's.
http://www.miata.net/garage/tirecalc.html
My truck at:
http://www.streetscenemag.com/ViewOw...?ProfileID=202
My truck at:
SilverX
Thanks that is a great site. It allowed me to make a decission on what tire size to order. Really neat how you can see the difference in size at a glance...
again thanks....
again thanks....
