Need Larger Tires
Want larger tires and rims. I have a 2001 4X4 Supercrew. How wide of rim should a get 16.5? Need tire size also, needs to be wider. I like BFGoodwrench AT. Please post pictures if you have any. Thanks.
http://www.fseries.com/uploadgallery...7&Show=1&Page=
------------------ Supercrew 4x4 Lariat Solid Black 5.4 Triton 3.55 Limited Slip 6750# GVWR Package Skid Plates Moon Roof Sliding Rear Window Trailer Tow - Class III Cargo Cage Grey Leather Captains Chairs 6-Disc CD Changer Mods: 305/70/16 ATS, AR Atlas 16x8 Chrome Westin Steps Planned: Dual Exhaust, Toneau Cover and Expedition Console Mod. Another great Ford truck site -www.fseries.com Truck Pictures |
Did you have to cut anything, or raise the truck? Looks GREAT!!!!! How does it tow a load with larger tires. I will be pulling 4500lb boat, or 16ft trailer with 3 ATVS on it.
Goochy,
I just had BFG 285/75/16 tires mounted on my 2001 F-150 SuperCrew on the stock 16" rims. They fit and look great. Didn't know if they would fit but the guys at discount tire have always been willing to 'try' a tire on my vehicles to ensure good fit, no rubbing etc.. They put one on and after we'd tried the steering from lock to lock and eye-balled the clearances, I gave the thumbs up and as a bonus, we found out that this tire JUST fits the spare tire well under the rear. The guys didn't think the spare was going to fit but voila, fits like a glove (any taller however and I'd be driving on the next size down). If you are interested in comparing other sizes/prices try www.discounttiredirect.com They have a good selection of BFG ATs with pricing information. ------------------ 2001 SuperCrew XLT Oxford White, Med Graphite Interior 5.4 Liter 4X4, LS Rear, Tow/Trailer Skids, Captains Chairs ------------------ 2001 SuperCrew XLT Oxford White, Med Graphite Interior 5.4 Liter 4X4, LS Rear, Tow/Trailer Skids, Captains Chairs |
No, there was no cutting needed. From what I can tell there would be no clearance problems lock to lock or at the bump stops. Granted, this beast hasn't seen any mud holes yet but I haven't heard any rubbing at all.
Thanks Deesrt Dog, and KKirt. I really Love Kirts 305/70/16 16x8 set up. I'm going to try that, because I will not be off roading it anyway. Looks like they fit great! Kirt what about your spare can you still use it? Do yall pull a load with the tires, how does it pull(5000lbs or less). Do you use overdrive or cut it off when towing? Thanks Alot I had 1 mile on it Nov 25 now I have 300 on my first FORD ever, the Z71 had to go.
I'm not sure about the spare. I would be hesitant to put it on the rear axle since I have Limited Slip. If I put it on the front I bet it would pull pretty hard. Oh well, I haven't had a flat in a long time so it's not a big concern for me.
As far as towing, I haven't done any yet. Although I only had the truck a day before I put the new treads on I didn't feel that much of a loss in power. The Crew runs great! |
Goochy,
If my calculations are right, I think that you will be able to have the 305 as a spare. This is the calculation I've used to compare my Tire sidewall height with the 305: My sidewall height is: 285 (millimeters) X .75 aspect ratio = 213.75 kkirt1's sidewall height is: 305 X .70 = 213.5 So, kkirts1's tires are wider by 2 Centimeters (not quite an inch) and just slightly shorter. The overall height is what was in question when trying to get the spare to fit so I think you'd be OK. The extra width on the 305s would definitely give the truck a more aggresive look. I like the BFGs because I've owned them in the past and didn't want to fork over more than the $160.00 per tire to go to a larger BFG. Good Luck ------------------ 2001 SuperCrew XLT Oxford White, Med Graphite Interior 5.4 Liter 4X4, LS Rear, Tow/Trailer Skids, Captains Chairs |
Thanks alot, Going to try to sell my stock setup, then go BIG. Getting bed liner ,bed cover, windows tinted, grill insert, then tires and rims. Should look great then.
2001 supercrew 4x4 limted slip 3.55 gears XLT 60/40 seat White 5.4 |
