Auto Trans ReCalibrator
Old Oct 19, 2000 | 11:06 PM
F150Y1997's Avatar
Post Auto Trans ReCalibrator
Greeting Everyone!!!
Have been lurking for the last few days and have decided to join you folks. Hope to contribute in anyway I can. Now to my question...does anyone have any experience with subject device? I'm planning on putting Michelin 175/70R16s (I'm too cheap to buy larger rims just yet) on my truck and was searching the internet to figure out how to recalibrate the speedometer. Thought I had things well in hand until I came across literature for subject device and how it "helps". Kind of scared me. Thought all I'd have to do was change the VSS driven gear. Given what was said this thing will do I'm also now worried it might bump signals with my future goal of also acquiring a Superchip. Any thoughts??
Jerry
Old Oct 22, 2000 | 12:02 AM
F150Y1997's Avatar
Post
Ok Folks, sorry. Just noticed why no one is taking my question seriously. I meant to say 275/70R16.
Jerry
’97 F-150 4x4 SuperCab XLT Flareside; 4.6L EFI; 4-Spd Auto Trans; Pacific Green Clearcoat Metallic; Preferred Equipment Package 507A; Min Payload Package; 3.55 Regular Axle; Electric Shift (4x4); Trailer package; 4-wheel ABS; Cloth Captain’s Chairs; Remote K/Less Entry/Anti Theft; Muth Signal Mirrors; Westin Chrome Step Bars; Specialty Covers Truck Bed Cover W/Remote & K&N Filter.
Old Oct 22, 2000 | 11:11 PM
2000 F150 4x4's Avatar
Cool
If you plan to get a Superchip, post in the computer section, I *think* they can fix your speedo with the chip..
175's would be a little small heheh
What size do you have now? As long as the overall diameter doesn't change much you'll be ok..
2000 F150 XLT 4x4 Short Bed. Amazon Green, 5.4L, SuperCab, ORP, Tow Package, Sliding Rear Window, Electronic Shift, Keyless Entry, LT265-70-17 Tires, Clarion Pro Audio, Herculiner Bedliner, Air Silencer Removed.
1994 SVT Mustang Cobra. #1032 of 6009. Black coupe with black leather int., 3.73 rear, Bassani Exhaust, Aluminum D/S, Bridgestone RE-71 255-45-ZR17
My Home Page
Old Oct 23, 2000 | 03:32 PM
JMC's Avatar
JMC
25 Year Member
Post
F150Y1997,
You are in luck. The 97-98 F-150s can be corrected by changing the gear that drives the VSS. You need a pink 19 tooth gear.
PART # 17271-C0DD-C.
Regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks,
Borla Cat Back, Headman Headers,
Modified Air Cleaner Outlet Tube
and air box, Shortened MAF sensor tower,
K&N air filter,
Superchips
[This message has been edited by JMC (edited 10-23-2000).]
Old Oct 23, 2000 | 08:46 PM
F150Y1997's Avatar
Post
All, Thanks for the comeback. When I originally posted it was out of desperation with trying to figure out the VSS driven gear recalb. Hence the question about the Trans Auto ReCalibrator. But I think I'm getting to the end of my tunnel. As JMC states, changing the driven gear will solve my problem. But here is the rub. I tried backing into the formula to figure out what the tranny drive gear tooth count was and doing the math for an 8 tooth gear (assumption here) and 235/70R16 tires, which Ford says should be on this truck, with my 3.55 axel, yeilds a driven gear for the VSS with 19.78 teeth. Well, being the unlucky guy that I am, when I pulled out the VSS and looked at the gear it was Red with 21 teeth. Now I understand there will/should be a "range" but I thought it'd be rounded up to 20 teeth not 21. I've yet to crawl under the truck and get the tranny tag number. Now I'm torn between getting 265/75R16 or 275/70R16 tires. Doing the math the driven gear comes to 18.097 and 18.383 respectively, assuming an 8 tooth drive gear again. So, rounding up, JMC's 19 tooth gear seems to be on the money and seems to follow my situation. I'd just like to know what I've overlooked in factoring in here since my original VSS driven gear has 21 teeth.
Jerry
’97 F-150 4x4 SuperCab XLT Flareside; 4.6L EFI; 4-Spd Auto Trans; Firestone P235/70R16; Pacific Green Clearcoat Metallic; Preferred Equipment Package 507A; Min Payload Package; 3.55 Regular Axle; Electric Shift (4x4); Trailer package; 4-wheel ABS; Cloth Captain’s Chairs; Remote K/Less Entry/Anti Theft; Muth Signal Mirrors; Westin Chrome Step Bars; Specialty Covers Truck Bed Cover W/Remote & K&N Filter.
