Wheel lug torque ?????
Old Oct 31, 2003 | 12:52 AM
woodswalker1's Avatar
Can anybody tell me the wheel lug torque specs on a 2000 2wd f-150 with the factory 17" wheels??? The brain surgeons at the WalMart tire center have broken a lug twice in the last to visits for tire rotation and balancing.They claim the computer calls for 150ft/lbs per lug??? Many thanks in advance....
Old Oct 31, 2003 | 06:04 PM
mrgrizleebear's Avatar
lug nut torque
chilton manual 26666 says 83-112ft.lbs,dealer i bought my truck from says 100ft.lbs hope this helps,walmart should fix lugs free of charge. doug
Old Nov 3, 2003 | 10:49 AM
sagittarius1's Avatar
All 2000 F-150's (excluding F-150 equipped with 7-stud wheels and the 7700 payload group), Expeditions and Navigators build after 11/27/99 has the new wheel studs and nuts. The thread diameter increased from 12mm to 14mm and torque to 150 ft-lb.
12mm lugs = 100ft-lb
14mm lugs = 150ft-lb
