Lug size
Old Oct 25, 2003 | 03:57 PM
jbless's Avatar
Lug size
Does anyone know the lugs size for an F150 Supercrew Larait? I'm looking for a new set of wheels and am not sure what will fit. Is the size 5 x 135?
Old Oct 25, 2003 | 07:33 PM
conner's Avatar
Registered User
jbless
the lug nut size on your '03 F150 is 14m.m. the bolt pattern is 5 on 135 m.m. good luck on the new wheels--there are alot of choices out there.
conner
Old Oct 26, 2003 | 12:56 PM
dekm's Avatar
Does anyone know the lug size on a 1999 F150 4x4? Are they 12 mm or 14mm?
Old Oct 26, 2003 | 09:37 PM
conner's Avatar
Registered User
jbless
in mid 99 the ford changed from 12 m.m. to 14 m.m. the easiest way to tell is 12 m.m. takes a 3/4 socket--14m.m. takes 13/16
hope this helps, conner
Old Oct 27, 2003 | 08:29 PM
jbless's Avatar
Thanks for the info. I'll let you all know what I decide.
Old Oct 28, 2003 | 11:11 AM
sagittarius1's Avatar
2000 F-150's (excluding F-150 equipped with 7-stud wheels and the 7700 payload group), Expeditions and Navigators build after 11/27/99 has the new wheel studs and nuts. The thread diameter increased from 12mm to 14mm and torque to 150 ft-lb
Old Feb 18, 2004 | 07:36 AM
lindpaik's Avatar
F-150 2003 Model lug nut size
I am trying to find out whether it is possible to use any lug nuts smaller than 21 mm hex (~ 13/16") for the M14x2.0 wheel studs that the F150ies now come with; i.e. are there lug nuts availalble for this thread that would be only 3/4" hex?
Many thanks!
K
