What brand of wheels to you like?
We have all seen and responded to the threads concerning Wheels/tires size combos. It is also clear that many have strong opinions on the style of wheels that go well with out trucks. I am interested in opinions about the different brands of wheels. I, for example, am partial to the style represented by American Racing Baja, Eagle 589's, and Mickey Thompson classic. However, I have no experience with these brands and how they wear/hold up. How about some opinions?
BLK 2000 F150 XLT 4X4 SuperCab SB, Shift-on-the-fly, 5.4L, 4R70W, 3.55 LS, 4-Wheel disc/ABS, ORP, Keyless, PWR Seat, Slider, Soft tonneau, Cab steps.
MODS: Rhino, Molded flaps, Mobil1 0W-30
I've had my Baja's for a couple of months now. So Far So Good.
98 F150 2WD,Bright Red, Regular Cab, 4.2, 3.55, 5 Speed, Superchip, 2 Superchip Decals (I Think They Add 5 HP Each), 3 Inch Bullseye Lift Spindles, 3" Body Lift, 1" Coil Spacers, 3" Blocks In Rear,Manik Grill Guard,Nerf Bars, Vent Visors,Air Box Mod, Fog Lights Mounted In Front Air Dam ,4 Kc DayLighters, Back Up Lights, Alpine CD Player, 2 Kenwood Amps, 10 Inch MTX Blue Thunder SubWoofer, Tinted Windows. 35" BFGOODRICH ALL TERRAIN KO'S Mounted on 16.5x9.75 American Racing Baja Rims
<A HREF="http://www.zing.com/picture/pf95408d4c385a927598e7884a5151a2a/ffd9add3.jpg" TARGET=_blank>
</A> <A HREF="http://www.zing.com/picture/p7e554b755e2bb9aa66f774b76d669a34/ffd9add2.jpg" TARGET=_blank>
</A> <A HREF="http://www.zing.com/picture/pe0557f5ae565a8da25e9ce11b08009df/ffd9add1.jpg" TARGET=_blank>
</A> <A HREF="http://www.zing.com/picture/p810cf5ac82eb57b84a62f699fb0f38e7/ffd9ad72.jpg" TARGET=_blank>
</A> <A HREF="http://www.zing.com/picture/p3d23039451896f609154656f22698b8f/ffd991ca.jpg" TARGET=_blank>
</A>
CLICK THE PIC FOR A BIGGER ONE
..........."IF YOU CAN'T STOP,
SMILE AS YOU GO UNDER"...........
'00 Toyota Celica GT( Wife's Car )<A HREF="http://www.zing.com/picture/p5ef23f8639c03b4f05f21e4f35c15cfb/ffd9ad71.jpg" TARGET=_blank>
</A>
Pics @ http://www.angelfire.com/la2/ccla/
[This message has been edited by ccla (edited 03-21-2000).]
SMILE AS YOU GO UNDER"...........'00 Toyota Celica GT( Wife's Car )<A HREF="http://www.zing.com/picture/p5ef23f8639c03b4f05f21e4f35c15cfb/ffd9ad71.jpg" TARGET=_blank>
ccla,
I have the same truck as you do(Red 1998 F150 STX Reg Cab) and I wanted to lift my truck. I wanted to know how you like it, how it drives and how it handles off road. Also I saw in your signature that your truck has 3.55 gears, are they LS or regular axle I have the regular axle and was concerned about rear wheel spin.If you do not mind I wanted to know what you paid for the lift, wheels and tires. Also how long did it take for the install.
I like Crager Super Sports, a chrome spoked wheel, but they don't make them that will work on my truck.
I have Centerline Starfires, a chrome spoked wheel. They are a good substitute for the Cragers, but the chrome job is adequate at best. I will go else where for my next set of wheels.
BOB
97 F150 Lariet 4X4 SC Everything except ESOF plus Line-X Bed Liner, Power Rear Slider, 16X8 Chrome Centerline Starfires, 305-70 Goodyear AT/S, Alpine Alarm, Deflecta-Shield Sportrends Running Boards, Edelbrock IAS Shocks, a new "no piston slap" 5.4, and a new "no-crack" door.
BOB
....MHZ, Here's what I paid
* Spindle Lift - $630.00 With Blocks
* Body Lift - $130.00
* Coil Spacers - $14.00
* More Blocks Rear - $30.00
* Rims & Tires - $1244.00
The Spindle Lift took Like 4-5 Hours to do.
The Body Lift took A Weekend. Cause we ran into clearence problems with the 35's. Thus the coil spacers and more blocks
It rides a little rougher now. But that may have something to do with the fact that my shocks are fully extended when I'm sitting still now.
XLTJAKE,
interesting topic.
I am had a set of American Racing directionals and although the quality of the wheel was good(spins true) the clear finish was not so good.
A buddy of mine has a set of Centerline Hellcats on his Jeep with 35-12.5-15 BFG Mud Terrains and this set up looks bitchin.With out a doubt the best tire/wheel combo going.
Just my 2 cents.
99 F 150 4x4.ORP,S/B 4.6 4.10 gears, Gibson 3" cat back. K&N filter. Soon to be Superchiped
interesting topic.
Just my 2 cents.
jarrettruelz88
That's the kind of info I am after. All these wheels should look great out of the box, but what about after a season or two, how do the finishes hold up?
XLT Jake
I have Centerline Saber rims with 275/60hr-17 tires.They make my truck handle much better, and the ride is much smoother.
I looked at the M/T rims, they are nice but pricy, and there customer service is terrible.The Centerlines were priced better, and there customer service is much better.
I see you are from the Boston area, I live in Waltham. Now that spring is here I think we should have a Massachusets get together.
1999 F150 4x4 4.6V8 regcab/shortbed
Oxford White with Wedgewood Blue two tone, with Blue Captains chairs
Bassani Cat Back, Superchip,Modified intake with modified K&N filter.
Centerline Saber rims 17x8" with Firestone GTA 275/60hr-17 tires.
DonC I am from Boston also,I used to work for Wheaton Electric in Waltham for about 4 years, you might have seen my Black lightning driving around Waltham last summer.Great truck but I had to get rid of it a little to impracticle driving to construction sites throughout Boston plus the winters, Traded it for the truck I have now which is another great truck but another slight problem.I work all over Boston and sometimes have to park in garages with a 6'6" clearance.The truck is about 6'4" factory.I would like to upgrade tires to bigger but I really can't get much taller any ideas?
99 F250 XLT LD 4X4 S/C,5.4,3.73 Limited slip,Bright red clearcoat ,4whl abs,remote start w/keyless entry and alarm,chrome rims,tinted,westin nerf bars,factory tonneau,superchip,K&NGen II fipk,pioneer in dash cd,pioneer amp,infinity kappas all around,Lund front runner bug sheild.Gibson split rear,stull SS grilles.
Just like CCLA I have the American Racing Baja wheels, and they are great. Look really good on a 4x4, or a lifted 4x2 for that matter
Good luck.
Patrick aka Mudder Arlington Texas (D/FW), member of the Texas Chapter club DAYLIGHTER edition F150 ®, Black 98 S/S S/C F150 4x4 0RP 5.4 3.55ls, Ramsey Pro 8000 hidden winch, Grizzly roll bar, Superwhite Bulbs, 2 Baja back up lights, 8 165 watt KC Daylighters, 4 chrome, 4 black (I come alive at night), Manik grille guard, Westin step bars, Rhino Taillight guards (thanks Pony), Magnum bug shield, Sonic aluminum treadplate 36" tool box, Flowmaster 40 series dual exhaust, Airaid High Flow system, Edelbrock IAS shocks, 265/75/16 BFG AT/S, American Racing Baja wheels, Cobra CB radio with 3' whip antenna, Escort Laser/Radar detector, Nokia cell phone, a Mobil Speed Pass on the back window, a F150 Online sticker, and a DAYLIGHTER sticker on the front windshield, and yes, I also have been infected with the infamous door crack. More to come for the Daylighting machine: JBA headers, BFG 285's, and a Lighted Ford tailgate logo. If you would like to see pics, email me at mudder46@hotmail.com or see pics at me and pony's website www.angelfire.com/ok3/ponysix8 , and to hear the Flowmaster exhaust http://www.angelfire.com/ok3/ponysix8/images/T005.wav
Mr.Daylighter "Go ahead, flash your brights at me, see what happens"
Also the Moderator of the Ford Trucks vs. GM trucks forum over on fordvschevy.com so check it out.
Check out the Toughest SOB in the WWF crush the Rock's Lincoln: http://www.amta.net/files/sc-2.avi
OH HELL YEAH!
[This message has been edited by mudder (edited 03-23-2000).]
Good luck.------------------
OH HELL YEAH!
I have the Centerline HTII Polished Aluminum rims, currently greased up with lots of moly to protect them from the winter. I had a set of Ultra 5 Stars on my S-10, and in less than six months they were rusted and pitted terribly. NO customer service, total waste of time. Avoid these rims like the plague!!
Once again, just my opinion, loosely based on actual events.
