Can't Remove Rear Brake Drums
Old Oct 11, 2003 | 08:19 PM
redcamper's Avatar
I have a 1999 F150 Xl long bed reg. cab with 62,000. With winter coming up, I thought it would be a good idea to replace the rear brake shoes. I already replaced the front brake pads on the truck at about 50,000 miles. I know a little about some car repairs and I thought the replacing of the rear brake shoes would be easy enough, but can you believe I could only accomplish getting the tire rims off. I could not get the brake drums off! I backed off the adjustment nut through the small slot in the back of the wheel assembly and the drums are as tight as can be. Zero play, wobble,gap,wiggle, anything. I am overlooking something. Also, does this brake drum still have the cut out hole in the center to fit over the wheel hub? I would swear in looking at the center of the brake drum, the hub in the center and the brake drum are welded together! I would appreciate any tips on how to get the brake drums off and replacing the brake shoes. Thank you.
Old Oct 11, 2003 | 08:25 PM
Pestco1's Avatar
Especally in your area the drum can rust itself to the axle ( hub) you will prob. have to use some sort of penetrating oil in the grove between the drum and the axle. spray a little where the two should come apart. let it sit sometime( 15 - 20 Mins. would not be too long) then hit the top of the drum with a hammer. move around the circumfrence until the drum comes loose.
Old Oct 12, 2003 | 01:14 AM
DG13's Avatar
Use a propane torch to heat the drum around the hub until you hear a pop then pull it off.
Old Oct 12, 2003 | 01:19 AM
AjRagno's Avatar
The drums would be rusted to the axle (unless of course you have the parking brake on).
Honestly, I don't think you need to worry about rear brake shoe wear. I have 86,000 miles on my 1997 4x2 and the shoes still have plenty of life left. I thought about replacing them anyway, but it looked just too complicated to perform this job prematurely.
Old Oct 12, 2003 | 01:38 AM
AjRagno's Avatar
Old Oct 13, 2003 | 09:46 AM
KevinDog's Avatar
Dude,
I just went through the same thing. I thought my drums were rusted on more than anyone could understand. The solution is simple - just tap the drum with a regular hammer as close to center as you can (between the studs) and work your way around. After tapping around for 3 or 4 minutes it will eventually loosen. It's the constant vibration that will loosen it, not the big whacks.
