NEED LARGER TIRES
Old Sep 7, 1999 | 05:44 PM
MN99F150's Avatar
Cool NEED LARGER TIRES
I HAVE A 99 F150 AND WANT TO PUT LARGER TIRES ON IT I HAVE THE 17" RIMS I FOUND A SET OF TIRES THEY ARE M/T 34x11.50 AND I WANT TO KNOW 1 IF THEY WILL FIT UNDER MY STOCK BODY (TIRE SHOP SAID THEY WILL FIT?)
AND IF THE WILL FIT ON THE STOCK RIM WIDTH
OR IF ANY ONE ELES HAS FOUND ANY OTHER TIRES THAT WILL WORK LET ME KNOW THANKS..
[This message has been edited by MN99F150 (edited 09-08-1999).]
Old Sep 7, 1999 | 06:22 PM
Mark G's Avatar
Wink
One shouldn't use all CAPS on all of their posts.
You can edit by clicking on the pencil/paper Icon above your entry.
Welcome aboard and good luck with your posts.
Old Sep 7, 1999 | 10:15 PM
Squanto804's Avatar
Post
MN99F150, Boy, it would be a tight fit. It would probably rub quite abit. I would think about possibly intalling a body lift. 33" tires fit and even those rub sometimes. The 11.5 would fit on those rims which are about 7" wide and keep them under the fenders.
97 F-150 Black, 4x4 XLT ext.cab,sb,offroad pack.
4" Susp. lift, 3" body
4.56 gears w/LS,Borla exhaust
35" BFG.,16.5x9.75 Weld Scorpio V wheels, Edelbrock IAS Shocks,Lift Lips,
K&N Filter, TransGo Shift kit,
Bug shield,Tinted windows
Sony ES head unit,Sony ES changer,MTX Thunderform sub,Boston Acoustic Pro-Series up front, Polk in rear,PPI & Coustic Amps,Alpine Alarm
Check it out at:
http://members.aol.com/squanto804/scottwebpage.html
Old Sep 8, 1999 | 02:36 PM
Squanto804's Avatar
Post
I was happy with the body lift kit from Performance Accesories. It cost about $120 and has everything you need. You can get them in 2 or 3 inch lifts.
Check it out at:
Old Sep 8, 1999 | 04:59 PM
MN99F150's Avatar
Cool
WHITCH ONE DO THINK WOULD LOOK AND WORK BETTER
Old Sep 8, 1999 | 06:03 PM
Squanto804's Avatar
Post
One inch won't make that much difference. I'd probably go with the 3". Are you going to do this yourself?
Check it out at:
Old Sep 9, 1999 | 12:34 AM
MN99F150's Avatar
Thumbs up
thanks for the advise iI think I will look into a body lift. what brand would you rate the best I don't whant the cheepest one and end up with what I paid for..thanks for the help..
99 F150 x-cab ORP bright red
crom rocker pannels flowmaster
tunnel cover
putco bed rails
lund bug guard
headlight covers
in-dash cd player
Old Sep 9, 1999 | 11:36 AM
MN99F150's Avatar
Red face
not sure yet I haven't looked into that much.
Why how hard is it to put in, I have tons of tools and a air compressor so I have not dicided that part yet..
