Rear Brake pad Change ?
Old Jun 8, 2003 | 03:06 PM
First time Ford's Avatar
Question Rear Brake pad Change ?
Just wondering if anyone had the procedure for changing the rear pads on a '00 F150 2wd with disc brakes. I've changed the front pads and they were pretty straight-forward, but the rears look a little more involved. Any help would be greatly appreciated.
Thanks.
Old Jun 10, 2003 | 07:04 PM
Anyone?
Old Jun 25, 2003 | 04:44 PM
01screw's Avatar
There's really nothing more complicated with the rear, if you did the fronts, you can do the rears. Basically the same procedure, pretty straightforward as you mentioned. Just unbolt the two bolts that hold the caliper to the bracket and the whole caliper comes off, spread the piston back into the caliper and install the new pads and bolt the caliper back on.
Old Jun 25, 2003 | 10:52 PM
I was just wondering since the pads for the rear came with four metal clips about an inch and a half long. Without pulling the tire off, it looks like there's only one clip on each wheel. I guess there's either another clip on the inside pad or Ford gave me a couple of spare clips... I guess I'll find out this weekend... thanks for the response...
