Need a longer E-brake cable!!
Old May 1, 2003 | 11:08 AM
Motorider187's Avatar
We put a 6" lift on my 01 f150 extended cab 4x4. After the lift we had to put the stock tires back on and the ebrake cable was pulled tight against the tire so we took it off knowing that the 35" tires were gonna rub worse. There is no adjuster on it!! Does anybody know if you can buy longer ones or extensions or somthing. so i can use it.
Old May 1, 2003 | 11:17 AM
Jimb's Avatar
Check out the cable from an supercab long bed?
Old May 1, 2003 | 05:55 PM
Hey thats a good idea! Think ill just do that.
