Ultimate Verdict On 315/70/17?
Old May 19, 2003 | 05:06 PM
powerdome's Avatar
So will a 315-70-16 fit on a 1fiddy with the bars cranked?
Old May 21, 2003 | 06:46 PM
AntScrew's Avatar
Remember the key here is they will fit on stock wheels with stock offset. Most if not all aftermarket wheels with 35's will NOT fit. Any wheel with a width of 8" or more will not work with this setup.
I must say that it is pretty sweet to be able to fit 315/70R17 on the fx4 wheels by just cranking the T-bars and some trimming.
Ant
Old Jun 20, 2003 | 01:56 PM
36fan's Avatar
RebelYell,
When I got got 2000 ORP, 3.55 gears were the only rear end available w/ the ORP - actually the 3.73 could only be had w/ the 7700 GVWR package. The tach was listed as part of the ORP and 'Sport' packages.
Apparently Ford made minor changes in the last couple of years - I wish I could've got the 3.73 back then
Old Jun 30, 2003 | 02:18 PM
kippy's Avatar
Registered User
I had a 2001 F150 with a set of 315's under it with NO LIFT. Adjuested the torsion bars and trimmed a small area on the back of the rear fender well. (Could not see it unless I told you where it was and you were looking for it) Only reason I had to trim that is b/c I was hauling a 20 ft trailor with a 4000lbs tractor to my home once a month and it rubbed very slightly because of the rear sagging. I have a few pics that I will try to post tonight or if I can't figure it out I will forward them to someone to post for me. My addy is kip@earthlink.net if someone wants me to send them to them to post.
Old Jun 30, 2003 | 02:27 PM
kippy's Avatar
Registered User
I did forget that before the tires were installed I put about a 1/2-3/4 spacer between the frame and the bumper. You could not tell it was spaced (no gap) I did this to avoid any trimming (with I didn't have to do in the front) Don't know if or how bad it would have been if I would not have spaced it. Loved the look and will be trying to fit them under my 04 when it arrives.
Old Jun 30, 2003 | 05:48 PM
STWater's Avatar
I dont have an FX4, but my F150 4x4 Lariat came with factory 17" rims (not the FX4 rims). Will the 315/70/17s fit that rim also? If so, I think Im gona order a set very soon. Thanks.
Old Jul 1, 2003 | 03:01 PM
cj1975's Avatar
Check out this site....this set up is 315's on stock 17's. I have these same wheels and was thinking the 305's instead. But this truck is great looking....He also has a 3" body lift.
https://www.f150online.com/galleries...w.cfm?num=3209
Old Jul 2, 2003 | 09:41 AM
AZSCREW's Avatar
How did he get white lettered 315/70/17's? They do not have white lettering!! Can you do it your self?
Old Jul 2, 2003 | 03:54 PM
kruck's Avatar
He painted them him self
Old Jul 2, 2003 | 04:23 PM
AZSCREW's Avatar
What type of paint do you use? Where can you get it?
