Changing From 265s to 285s..How Will This Affect Performance?
I'm going to get rid of the Goodyear RT/S tires that came on my Screw as I think they are lousy in the rain (and we get lots of that here). I'm looking at some Goodrich TAs in 285 as well as some Rossi or Modern wheels. My question is will this change affect my acceleration and towing? I will be staying with a 17" wheel.
yes, your acceleration and towing will be effected, but only if you change the overall diameter of the tires (not width) from what you have now.
A larger diameter would reduce your towing ability a bit, and make the truck a little slower on the start. It may increase your highway gas milage when empty. It would also reduce braking ability slightly.
A smaller diameter tires would have the exact oposite effect, but usually don't look as good as larger tires, JMHO.
It just depends on what is more important to you. There are pros and cons with every size/diameter choice.
