Cruise is hard to kick off
Old Feb 27, 2003 | 07:34 PM
97WhiteLariat's Avatar
A couple weeks ago I couldn't get my truck out of park. I figured out the trick to it and drove it a day or two. Realizing that my brake lights didn't work and that applying the brakes didn't disengage cruise, I changed the brake lamp switch and it fixed the problem. Today on my way home from work, cruise was hard to disengage with brakes again. I can get it out of park and my brake lights work...any ideas????
Old Feb 27, 2003 | 08:34 PM
TexfordD's Avatar
check the wire at the connector(at the switch)...right where the crimp is the wire is probably cut...been several instances of it including mine..I have a '97
Old Feb 27, 2003 | 11:14 PM
K thanks Tex...will do.
Old Mar 12, 2003 | 08:03 PM
Tex, Thanks for the pointer! Finally, got around to checking it out...sure enough it was a broken wire. I guess when I changed out the switch, I aggravated an upcoming problem. took 30 min to fix. Thanks again.
