ABS Problem
Old Feb 13, 2003 | 11:52 PM
trains1's Avatar
ABS Problem
I have a 2000 F150 and the ABS light came on about 6 weeks ago at engine startup. I got some feed back from this site and chaged VSS on the rear end. I disconnected both battery terminals while I put in the new VSS. The light remained on, and I still don't have ABS brakes. I also had 2 different places try their scanners on it and it does not show any problem code. Anyone have any ideas?
Old Feb 14, 2003 | 10:11 PM
danny owens's Avatar
abs
tell us if its rabs(rear antilock) or 4wabs(4 wheel antilock) and we might offer some help. they diagnose differntally.
Old Feb 15, 2003 | 05:20 PM
trains1's Avatar
They are just rear anti-lock.
Old Feb 15, 2003 | 07:08 PM
this system is not diagnosed with a scanner. you have to locate the black/orange wire in the right front kick panel, unhook it from the red wire, turn key to run, ground the bk/o wire until the abs lamp starts flashing, then read code.
Old Feb 16, 2003 | 08:54 PM
trains1's Avatar
I will give this a try on Monday. If and when I get a code, is there somewhere I can look that will explain what the code means.
Old Feb 16, 2003 | 09:51 PM
abs
i'm sure there is access somewhere online but you can post the code here and someone will reply.
Old Feb 18, 2003 | 05:03 PM
Silver 2002's Avatar
n/m
