Wheel replacement...problems?
Do you guys see any reason why I can't put my 15x8 5 lug wheels w/33's from my CJ on my 2000 4x4 ORP? I checked it out and it looks like they'll fit.....will I have any problems.
thanks
thanks
Your CJ probably has the 5 on 5½ pattern. The F-150 has a 5 on 135mm. I do not think they will fit. The next hurdle is the wheel diameter. A 15 inch wheel will rub on the front calliper unless you have a large positive offset or very little back spacing.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
Actaully JMC i think you mean he would need negative offset .Pos offsets put the wheel further into the wheel well neg bring it out
Richard D.
In fact that is the problem i currenly have with my new rims is I have a +14 offset and with my LT 285/75/16 tires i think they may end up hittine the upper ball joint once the tiere is mounte onto the rim.
Richard D.
