question on tire/gear sizes
Old Jan 12, 2003 | 10:43 PM
toddyman88's Avatar
Registered User
Wanting to know if anyone is running 315-70-16 (or 17) tires with 3.55 gears.(or 35x12.50's for arguments sake)
I really want to move up to this size when I complete my 4" rancho lift (hoping I have enough room) but dont want to hurt the transmission or anything else. Will consiter a gear swap but dont want to if I dont need to! Seems that the ability to turn off the od on these trannys should really help in a scenerio like this. Any feedback is welcome!
Old Jan 13, 2003 | 02:23 PM
ssinor's Avatar
Gear Ratio Guide for Larger Tires
This web sit might help.
http://www.4wheelparts.com/Tirel_Gear_Ratio.asp
Steve
Old Jan 13, 2003 | 02:30 PM
S'CrewLoose's Avatar
try this one too.
http://www.c5-corvette.com/tirecalc.htm
Old Jan 13, 2003 | 08:27 PM
toddyman88's Avatar
Registered User
great links, thanks guys!
Old Jan 14, 2003 | 09:58 PM
josey's Avatar
Bigger tires equal less lbs force; you'll gain ft (bigger tires) and lose lbs (force) from the torque (ft-lbs) generated at the axle. Percentage of lost will force be inversely proportional to the new (larger) tires circumference, ie., 110% larger tire = 90.9% traction force available as compared to the tire just removed.
For tire sze calculator, try http://www.car-videos.com/info/tirespecs.asp.
Cheers,
Brett
Old Jan 18, 2003 | 05:59 PM
toddyman88's Avatar
Registered User
Great first post brett, thanks alot! Gordon
