ABS and Brake warning lights
Old Jun 18, 2001 | 01:07 AM
Kenster's Avatar
Post ABS and Brake warning lights
Both the ABS and Brake warning lights came on at the same time Friday. A couple of times after stopping, then restarting the engine the lights went away but now they stay on full time. The Brakes seems to be working just fine. I immediately checked the owners manual which said that the brake light indicates low fluid and the ABS light says to have the system service. The brake fluid is full to the top. There is abolutely no leak of fluid. Any ideas?
1997 F150 XLT-STX, Reg. Cab,Oxford White, 4.2L, Auto, 3:55, Prestige Alarm System, MPC Wrap Bugshield, Spare tire Shield,
-It's a beautiful Thing!-
Also: 1996 Probe
1998 Mustang
1999 Taurus
Old Jun 18, 2001 | 05:09 PM
fordtec2001's Avatar
Post
first see if the float in the master cylinder is stuck push it down if not stuck then you need to have your system tested for codes
